MSUMOM
#1 Posted : Thursday, March 14, 2013 7:25:53 PM(UTC)
MSUMOM
My washer fills and agitates fine but will not drain water or spin excess water out. Tried unplugging and resetting but still doesn't work. If I manually move the dial to the spin cycle, it still doesn't work. I use to be able to go through the spin cycle with the lid up so I'm not sure it is the lid switch. All the model #s or name I found on the washer is, SureCare Two-speed KAWE570BWHO. Thanks!
#2 Posted : Friday, March 15, 2013 5:13:16 PM(UTC)
Hi,
Sounds like the problem is a bad lid switch.
- The lid switch Part number: 285671
