dwelsher
#1 Posted : Tuesday, March 12, 2013 7:33:36 PM(UTC)
dwelsher
I have a maytag freestanding lp stove.It has worked just fine last week and now it won't get warm or hot in the oven department. When I press the cook button it shows 350 for 5 seconds and it goes back to 100 degree like it usually did but nothing happens inside the the oven. Doesn't get warm or hot. I don't know whether I should try the temp sensor or what.I am hoping someone out there knows what to do.Thank you
Simon / APP Team
#2 Posted : Wednesday, March 13, 2013 1:21:49 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely the oven ignitor is bad. If it glows red and no flame - replace the ignitor
Part number: AP4096256
If it's not glowing check if it's getting the 120VAC from the control board.
Use the multimeter to check the voltage at the ignitor's quick disconnect plug.
If the correct voltage present - replace the ignitor. If not - control board.
Part number: AP4420158
Here are the breakdown diagrams and 04-Gas Controls parts for Maytag MGR5752BDW - AppliancePartsPros.com
Post the results.
Simon.
