hollywood1962
#1 Posted : 12 years ago
hollywood1962
I was trying to stop a squeak in the dryer, and in my rushing to take things apart, I forgot to unplug the unit, and i think the heater element shorted out after it fell. My bad! Now i need to take the drum out to get at the heater element. There are six screws on the drum. Three in the middle and three on the outer area at the back of the drum. My question is do I take the three from the middle or the three from the outer area, or all six. Thanks in advance!
RKF22
#2 Posted : 12 years ago
RKF22
Need the proper model number to see what you are working with.
hollywood1962
#3 Posted : 12 years ago
hollywood1962
Here is the picture from the inside of the door.
French door Ice Maker diagnosis.- diagnostic flow charts - part 2.pdf (1,463kb) downloaded 16 time(s).
hollywood1962 attached the following image(s):
hollywood1962
#4 Posted : 12 years ago
hollywood1962
Here is some more pictures. Tech Sheet W10280489 - MVWC400XW0 - part 2.pdf (1,696kb) downloaded 41 time(s).
#5 Posted : 12 years ago
You don't have to remove these screws at all. Instead you have to remove the whole drum from the dryer. The instructions are attached to the post.
File Attachment(s):
Dryer disassemble procedure.doc (20kb) downloaded 3 time(s).
hollywood1962
#6 Posted : 12 years ago
hollywood1962
Thanks for the help! I'll have to give that a try tomorrow night. I just finished reffing a hockey game, and it's 10:15 here in Winnipeg, so I'm not going to start working on it now. Thanks again!
Maytag dryer drum removal (Dryer Repair)
by Tomjenks 10 years ago
drum removal for whirlpool (Washer Repair)
by hnsberk 12 years ago
Drum removal (Washer Repair)
by aaron2011 14 years ago
Drum Removal Help (Washer Repair)
by HARRY HEN 15 years ago
Washer drum removal (Washer Repair)
by ianos 16 years ago
