I have a GE Monogram side by side fridge. The lights in the the freezer do not work, but they work on the refrigerator side. I know it's not the switch or the bulb. Any advice?
What is the complete model number of the refrigerator?
Originally Posted by: Gene What is the complete model number of the refrigerator?
Gene. It's model# zlss360drgss
There is the light transformers tray under the refrigerator (#549 at the diagram). There are two fuses in the tray. Try to reset them and check for continuity. replace if it's open. - The light fuse Part number: WR23X10269
Originally Posted by: Gene There is the light transformers tray under the refrigerator (#549 at the diagram). There are two fuses in the tray. Try to reset them and check for continuity. replace if it's open. - The light fuse Part number: WR23X10269
That was my issue. I had originally looked there and didn't realize there were fuses there. Thank you so much as you saved me a service call.
You are welcome. I'm glad to hear it was such easy fix.
Model #ZISP480DHASS light panel in refrigerator not working need help please Thanks
I have a side by side GE Model no PFS22SISBSS.
The display for the temperature both the refer and freezer does not display.
Is there a light behind the display. Tried to adjust the temp by pushing the cold or warmer button but no temp display?
Roland
I have a very monogram fridge freezer. It has 2 lights in the fridge side . One light is out. New bulbs don’t work if I move the live bulb from one side to the other , both sockets turn on. Any ideas
