trixkit
#1 Posted : Monday, February 25, 2013 11:37:04 AM(UTC)
trixkit
Hi,
I had a self inflicted power surge during a recent storm and fried a couple of fridge components and almost caused a fire.
The main computer/microcomputer was fried, I purchased a new one and replaced it. Everything was working except the evaporator fan, so the air was not cirulating.
After replacing the microcomputer, I discovered that I also fried the evaporator motor and it was causing a short. I replaced the evaporator motor, but it is still not running, doesn't seem to be getting power when connected to the fridge components. The evaporator fan works, I tested it directly. The fridge feed to the evaporator motor is only putting out 12 volts.
Could I have damaged the microcomputer again by installing it while the defective evaporator fan motor was still causing a short? I've tested the thermistors and they are fine.
Is there a way to test the main board? I suspect it is the problem, but would like to know for certain before spending $200.
The fridge is a kenmore side by side and about 8 years old. The mainboard is part # 8201517.
Thanks for any help
John
#2 Posted : Tuesday, February 26, 2013 11:48:17 AM(UTC)
Hi John,
What is the complete model number of the refrigerator?
