From what I've read here (and many other sites) I need a new motor in my Maytag Gas Dryer MDG9206AWW. Buzzes/hums but doesn't tumble...burnt smell if I hold the start button. There seems to be many motors available for this model. How do I know which motor to buy? I'm nervous about taking the entire dryer apart/putting it back and causing more damage trying to get any identification from the old motor. First time replacing a motor!:eek:
Groups: APP Team
I'm not sure how to get to the blower wheel, my set up is a little different than the diagram. I do see a rubber gasket hanging from what seems to be the housing blower but I can't tell how it should be sitting.
Groups: APP Team
Did you open the front panel and remove the bulkhead to get to the blower housing? What do you mean by your set up is a little different? It's the same model number isn't it?
Simon.
It is the same model thought maybe a difference between serial no.? The large plastic part connecting the lint trap to the blower wheel isn't named in the diagrams and couldn't find any screws or a way to remove it. That's where the gasket was hanging from, the plastic part and where it meets the blower. I got my fingers in the blower wheel after I moved the seal and it did seem stuck for a second then moved and turned the drum.
Groups: APP Team
Did you open the front panel and remove the bulkhead?
Simon.
Yes I did get it open and blew out some of the lint and hair while it was open
Groups: APP Team
Take the belt off the motor pulley and turn the blower. If the motor turns easily - replace it.
Simon.
Alright, since it's not the motor what do I do to make sure the blower wheel doesn't jam?
Groups: APP Team
What made you decide that it's not the motor?
Simon.
