neptuneslave
#1 Posted : 12 years ago
neptuneslave
The upper drying cabinet stays warm for days even after the cycle has completed. I can hear the components of the dryer creaking like they are cooling down and when I open the top cabinet it is warm. What should I look for to repair the problem?
#2 Posted : 12 years ago
What is the model number of the unit?
neptuneslave
#3 Posted : 12 years ago
neptuneslave
Sorry about that- the model is MCG8000AWW and the serial is 10459790EE- thanks!
#4 Posted : 12 years ago
Sorry for the delay.
Sounds like the problem is a bad relay board (#22 at the diagram).
- The relay board Part number: 53-4643
Here are the breakdown diagrams and Parts for Maytag MCG8000AWW Dryer - AppliancePartsPros.com
neptuneslave
#5 Posted : 12 years ago
neptuneslave
Gene,
Thank you. I ran the diagnostics on the touchpad and all buttons/LEDs passed. I also did the diagnostics of the logic board functions and all of those functions passed EXCEPT the shaker motor- I could hear the relay make up when the shaker motor was commanded to turn on, but the motor did not start. Perhaps this is also a problem with the relay board.
I unplugged the 3 wiring harness connectors from the logic board and the upper cabinet continues to heat, so this certainly points to the relay board as the problem.
Thanks for your assistance!
#6 Posted : 12 years ago
You have nothing to lose if you will order the part from APP and give it a try.
Keep us posted.
neptuneslave
#7 Posted : 12 years ago
neptuneslave
Gene,
Thanks for your help- I installed the replacement relay board that I ordered from Appliance Parts Pros.com and it took care of the problem. Your advise was right on!
#8 Posted : 12 years ago
You are welcome. I'm glad to hear it's up and running.
