I need to replace the light switch on a Kenmore 795.77544600 made by LG. Any advice on how to get to them and take them out would be greatly appreciated. Thank you.
Groups: APP Team
Hi. The door switches are located on top of the door hinges covers. The switch has two tabs one on each side. Use the flat screwdriver to squeeze the tabs and pull the switch out. Part number: 6600JB3007A
Good luck. Simon.
Thanks for advice for removal of switches. Originally Posted by: Simon / APP Team  Hi. The door switches are located on top of the door hinges covers. The switch has two tabs one on each side. Use the flat screwdriver to squeeze the tabs and pull the switch out. Part number: 6600JB3007A
Good luck. Simon.
Groups: APP Team
