the washer rotary start switch moves and i cane here it running but nothing happens when i turn the knob by hand the drum starts going and then stops i checked the pump mooter with a ohm miter and got a good rating
Groups: APP Team
HI.
Please explain clearly what is the problem with the washer.Be more detailed.
Simon.
Originally Posted by: howardr57  the washer rotary start switch moves and i can hear it running but nothing happens when i turn the knob by hand the drum starts going and then stops I checked the pump motor with a ohm meter and got a good rating Howard, With both the washer and the dryer having start and run issues, have you considered checking the power supply to both appliances ? You could have an issue in the wiring or breaker box, causing neither machine to start or run.
when i start the washer it will fill up and drum will run but it will not go into spin cycle and the water will not pump out i put a miter to the pump and got a good reading even when i turn the knob to spin and drain nothing happens i took the drain hose and put it to the floor some water came out and then stoped
Groups: APP Team
Hi.
Does the washer agitates?
Does the motor runs when washer is in the spin?
Check if there is 120VAC at the drain pump contacts when timer set for drain.
Simon.
