Forelorren
#1 Posted : Sunday, February 17, 2013 10:59:28 AM(UTC)
Forelorren
I would first like to give a little service history ; three years ago the control board was replaced,two years ago the drum and a year ago the drain pump was replaced. Recently started receiving the UL code so I replaced the suspension rod kit, once I did that it started showing the F51 code as well.I double checked for obstructions with the tub and checked the center bolt of the cover to the RPS,which was loose. I tightened that and the F51 code was corrected.I still however have the UL issue. The drum does not seem to spin perfectly centered at higher speed.The only stored code is F51. Not sure what to do next, RPS,stator or both? Possibly something else ? Any help/advice would be very appriciated.
Thanks in advance
Forelorren
#2 Posted : Monday, February 18, 2013 7:24:53 AM(UTC)
Forelorren
Spoke to soon still get the f51 code when it agitates in wash cycle,UL at drain and spin cycle.
