CWBurfle
#1 Posted : Saturday, November 3, 2012 2:43:30 PM(UTC)
CWBurfle
My Bosch single wall oven, HBL745A UC/01 turns on OK. After it has been in use for a while, the following is displayed when the door is opened:
"WAIT V0515 A0047 F000 L2H2EAC". The clock sets to something like "2:35", and the oven door goes through an unlick cycle. Once the unlock cycle is complete, the oven can be turned back on by selecting a mode and temperature.
The oven has to be in use for a while before this will occur.
CWBurfle attached the following image(s):
CWBurfle
#2 Posted : Sunday, February 17, 2013 9:01:16 AM(UTC)
CWBurfle
Since I was unable to interpet the error codes, I decided to call an authorized Bosch repair outfit to fix the oven.
The problem turned out to be the main (Mother) board. After the technician replaced the board, he and I took a look at the old one. There were a couple of components that clearly had overheated and been damaged.
