2 Pages12>
capnrobi
#1 Posted : Friday, February 15, 2013 1:12:27 PM(UTC)
capnrobi
I am trying to repair my Kenmore series 90 washer model 110.26912690 (or maybe 110.26912691)
Following troubleshooting:
lid switch - I shorted it, not the problem
drain pump hose - I lowered the hose, the wate drrained, no obstruction
water pump belt - direct drive, no belt
coin trap - I lowered the hose, the water drained, no obstruction
I removed and examined the pump - not frozen
I hear no noise at all when it should pump.
How do I test the timer switch, I have seen the chart, but I'm looking for instructions
robi
#2 Posted : Friday, February 15, 2013 4:09:17 PM(UTC)
Hi Robi,
Does it do anything or it's completely dead?
capnrobi
#3 Posted : Monday, February 18, 2013 3:45:53 AM(UTC)
capnrobi
Hi Robi,
It fills, it agitates.
It does not drain or spin.
robi
#4 Posted : Tuesday, February 19, 2013 3:02:55 PM(UTC)
Originally Posted by: capnrobi Go to Quoted Post
...It does not drain or spin...
Does the motor run at that time? Does it make any sound?
capnrobi
#5 Posted : Tuesday, February 19, 2013 5:09:19 PM(UTC)
capnrobi
No. No motor noise, no sound when it should be draining.
#6 Posted : Wednesday, February 20, 2013 2:50:28 PM(UTC)
Remove the washer cabinet and check all wires connected to the motor.
Unfortunately i could not find any electric schematics for this model. If you do have one and can post it here, it might help.
capnrobi
#7 Posted : Wednesday, February 20, 2013 5:40:28 PM(UTC)
capnrobi
Thank you, Gene
I will check the wires at the motor
robi
capnrobi
#8 Posted : Thursday, February 28, 2013 4:33:16 PM(UTC)
capnrobi
RR> Thank you, Gene
RR> I will check the wires at the motor
Wires looked fine. I checked motor.
http://www.youtube.com/watch?v=oHtLlqeChww
helped very little
http://www.applianceaid.com/direct-drive-washer-motor-help.php
[URL="http://www.applianceaid.com/direct-drive-washer-motor-help.php"][/URL]
did help
Start windings (black to yellow) 5 ohms - GOOD
High Speed windings (blue to white) 1.6 ohms - GOOD
Low Speed windings (white to white/violet) 0.3 ohms - PROBLEM
Does that fit the symptom of no drain?
Is it worth fixing?
robi
fairbank56
#9 Posted : Thursday, February 28, 2013 5:34:41 PM(UTC)
fairbank56
What about wht to wht/orn on the motor? (extra low speed)
When agitation stops, does the motor attempt to start in drain mode? Does the timer continue to move?
Assuming the lid switch is good, if the motor doesn't attempt to start for drain, I think you have a bad timer.
The low reading on the low speed winding does indicate a problem however, the motor always starts in high speed regardless if it's agitate, drain, spin, or selected speed via the speed switch. Drain in normally in high speed only anyway.
A clear picture of the wiring diagram and timer chart is needed to help you troubleshoot with multimeter. The different models have variations in the way they are wired.
Eric
capnrobi
#10 Posted : Sunday, March 3, 2013 7:06:20 AM(UTC)
capnrobi
Eric> What about wht to wht/orn on the motor? (extra low speed)
Has none.
Eric> When agitation stops, does the motor attempt to start in drain mode?
Silence after the click of the timer at the end of the agitation
Eric> Does the timer continue to move?
No. I thought it was waiting for a level switch to say the water is low enough to spin.
Manually advancing the timer does nothing.
Eric> A clear picture of the wiring diagram and timer chart is needed to help you troubleshoot with multimeter. The different models have variations in the way they are wired.
Diagram and timer chart are visible there on the machine. I can read wiring diagram but have no understanding of what the timer chart is saying or how to test it.
robi
Kenmore not draining completely (Washer Repair)
by csohio 12/23/2008 10:08:17 AM(UTC)
Kenmore not draining or spinning (Washer Repair)
by Alicornat 6/28/2008 12:45:10 PM(UTC)
2 Pages12>
