Frigidaire fdb520rhb2a about 2-3 years old continues washing cycle over and over, everything else seems to be fine, temp is good, drains perfectly.. I've pulled it out, and tested one part for continuity, and it tested good, i believe this part to be the high temp thermostat, when the dishwasher is laying on its front, it is located on the top right corner. Another part i tested and i removed was a little black part with "36j1hp" on the other side of it, when testing that part my meter stayed at 1. Would that be causing the problem, if so can i get a link for the part?
Any thing else I should check feel free to let me know..
Thanks!!
I did not measure it, but i opened it and put my hand in, wasn't hot enough to burn but was REALLY warm. last time I let it run as long as i could was two and a half 3 hours...
Should i try just bumping up my water heater just a bit? Also What all parts should have continuity?
Your dishwasher senses the water temperature inside and time of the cycle very much depends on the incoming water temperature and on how the heating element in the dishwasher works. The incoming water temperature suppose to be 120 °F. The water temperature inside the disheasher can be as hot as 150°F.
Originally Posted by: s_carp90 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Frigidaire fdb520rhb2a about 2-3 years old continues washing cycle over and over, everything else seems to be fine, temp is good, drains perfectly.. I've pulled it out, and tested one part for continuity, and it tested good, i believe this part to be the high temp thermostat, when the dishwasher is laying on its front, it is located on the top right corner. Another part i tested and i removed was a little black part with "36j1hp" on the other side of it, when testing that part my meter stayed at 1. Would that be causing the problem, if so can i get a link for the part?
Thanks!! I have the same model with the same problem. What have you figured out and how do I fix it?? Thanks
