Bkomperda
#1 Posted : Wednesday, February 6, 2013 2:59:00 PM(UTC)
Bkomperda
My oven will not work , when use bake will click i can see spark and smell gas but will not flame. When used matches will fire up and will work when gets warm after cools of it just clicks and no fire . When using broil work fine .im not sure is this igniter problem or something else.I tested solenoids and both reading 214 ohms.
#2 Posted : Thursday, February 7, 2013 1:48:56 PM(UTC)
Hello,
Remove the Bake burner and check the lighting holes near the igniter. The solution might be a new burner assembly.
- The burner assembly (comes with the igniter) Part number: 8190618
Bkomperda
#3 Posted : Thursday, February 14, 2013 3:40:10 PM(UTC)
Bkomperda
I found the problem, spider web inside burner.Thanks
#4 Posted : Friday, February 15, 2013 2:04:15 PM(UTC)
You are welcome. I'm glad you were able to find it. Very unusual!
Frigidaire wall oven model CGEB30S8CS1 oven will not turn on (Oven Repair (including Ranges and Cooktops))
by RHykawy 4/2/2021 2:00:36 PM(UTC)
GE Profile electric oven will not turn on (Oven Repair (including Ranges and Cooktops))
by toddlamp 3/31/2021 7:03:39 PM(UTC)
Frigidaire Gallary Electric Range Oven Will Not Turn On (Oven Repair (including Ranges and Cooktops))
by jaycevs 12/2/2014 5:28:35 AM(UTC)
Jenn-air double wall oven - lower oven will not turn on (Oven Repair (including Ranges and Cooktops))
by hjustice 9/28/2014 11:37:55 AM(UTC)
GAs range oven will not turn on (Oven Repair (including Ranges and Cooktops))
by JohnRogers 4/18/2013 8:21:57 AM(UTC)
Maytag oven will not turn on (Oven Repair (including Ranges and Cooktops))
by threeputt 12/10/2012 12:07:16 PM(UTC)
Need to bake/ oven will not turn on! (Oven Repair (including Ranges and Cooktops))
by ms michelle 1/24/2011 3:05:15 PM(UTC)
Oven Will not Turn On (Oven Repair (including Ranges and Cooktops))
by pete8960 3/25/2010 7:47:46 AM(UTC)
Frigadiare Oven will not turn on (Oven Repair (including Ranges and Cooktops))
by 29264 3/17/2010 10:58:24 AM(UTC)
by mcarp 9/25/2009 3:28:57 PM(UTC)
Kenmore gas oven will not turn ON (Oven Repair (including Ranges and Cooktops))
by skidoomxz99 8/20/2009 3:42:25 PM(UTC)
by rortega 7/11/2009 9:15:43 AM(UTC)
by CTHEESFELD 7/10/2009 6:30:11 AM(UTC)
Oven will not turn on, broiler works, stove top works (Oven Repair (including Ranges and Cooktops))
by caewart 6/19/2009 4:31:43 PM(UTC)
by craigjung 3/1/2009 1:21:19 PM(UTC)
