My problem is the key pad bake buttons/functions (for top and bottom ovens) works intermittently. I've read various appliance repair blogs on the internet & the most likely cause points to the ribbon cable on the control panel assy. I've cleaned, wiggled, bent, etc and at times I can get the bake buttons to function but only temporarily. I cannot definitely tell if the problem is with the control panel/ribbon cable assembly or the connector on the erc board.
Although I'm pretty confident the control panel (P/N AP3207356) is the part I need, I'm concerned that the mating connector on the control erc board could be the problem. Your thoughts suggestions before I purchase a new control panel. All other functions work on the stove. Thanks
The model number you posted does not come up. Verify and repost it.
Gene. Is it an American model?
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The model number you posted does not come up. Verify and repost it.
Gene. Is it an American model? Typo, a typist I'm not :) s/b Model JKP48CF1CC or JKP48C0F1CC. Made by GE... made by ????
