I'm positive about these two parts. The ribbon cable is a part of the control panel. There is nothing else what could cause it.
Hello, I have developed the dreaded F2 E0 error message on my Kitchenaid stove (model KGSA906PSS00, stainless steel). I would like to replace the key pad myself. Should I also order the control panel at the same time? My thinking is that if it is not the key pad that is broken then I'll have the control panel there to install, instead of waiting a week to have the part delivered. Or is the problem so likely to be the key pad that I'd be wasting my time and money on ordering the control panel?
Also, can someone please post a link to the correct parts I should order for the repair?
Thanks everyone!
Hi Gene, It is stainless-steel colored (brushed metal surface). Thank you!
You are welcome. - The stainless steel membrane switch Part number: 9756559ES
Click on the part number and scroll down to the Q&A section for the installation instructions. Gene.
Joined: 5/12/2024(UTC) Posts: 0 Location: Ontario Was thanked: 10 time(s) in 10 post(s)
Hi, ** GMC305PDB** Missing a digit or two after the B. **I have checked all other connectors and was afraid of damaging the ribbon cable to the keyboard or its connectors as I don't know how to remove it.** These parts are NLA :( Most boards have a plastic clip to release the ribbon from the key panel. Grip both ends and lightly pull outward away from the board. once the ribbon is released, try a pencil eraser on the ribbon end to clean it up and reinsert to re-test. 1:06 shows a key panal ribbon being disconnected. Link is here. I hope something here helps. jeff sr. |
