I replaced the idler pulley shaft lever assembly for the belt, and also replaced the belt. The dryer worked great for about 3 loads then it started shutting off in mid cycle and not re-starting until it sits awhile. I see it could be the overload protector stopping the dryer, which it now does after only 5 minutes of use. Everything looks to be put together correctly. Any Ideas??
