25 Pages«<1718192021>»
#181 Posted : Wednesday, January 30, 2013 8:16:53 PM(UTC)
The normal temperature range is -2°F to 5°F.
rrnworks
#182 Posted : Thursday, January 31, 2013 6:36:27 PM(UTC)
rrnworks
Hi Gene,
I can't believe so many things can cause the icemaker to stop working...the first I've seen in this entire post that replacing the optics, valve, and/or icemaker hasn't worked. Anyway, I turned the freezer temp lever from 3 down to 1 but the temperature has not changed. Any ideas?
Thanks,
Chris
#183 Posted : Friday, February 1, 2013 12:12:28 PM(UTC)
Hi Chris,
Normally it takes about 24 hours to see any changes after adjustment.
How did you measure the temperature? Don't rely on digital display if there is one.
rrnworks
#184 Posted : Friday, February 1, 2013 1:24:28 PM(UTC)
rrnworks
I'm using a regular analog freezer thermometer from home depot. It has been a couple days since the temperature was adjusted. Maybe a tad warmer at -12 degrees - still no ice.
#185 Posted : Friday, February 1, 2013 1:27:36 PM(UTC)
Try to raise it to at least -5°F. What is the temperature in the refrigerator?
rrnworks
#186 Posted : Saturday, February 2, 2013 8:12:56 AM(UTC)
rrnworks
Fridge is 38 degrees (temp control on 2). I have the freezer temp control all the way down to 1.
mcdbones
#187 Posted : Saturday, February 9, 2013 11:37:53 AM(UTC)
mcdbones
Gene,
*I have kitchenaid superba model#KSCS25INSS00
*Water flows from door but no ice
*Sensor does 2 blinks pause 2 blinks, when flap closed it's solid red
*I have tried testing voltage between N&L = ~35V
*Tried jumping H&T = completed about 1 revolution, water never activated
*Tried jumping again. now doesn't move & N&L = 0V
*Inlet valve not blocked or frozen
*Freezer was at 0-5 deg when started messing. now at 20 deg
*I'm wondering if having fridge hooked up to rev osm filter under sink would effect performance although we've had it that way in old house and worked fine.
I tried looking through most of these posts and entering as much info as I can to save you time. I really appreciate all the info you've given to others and any you can give me.
I will be ordering new ice maker regardless because coating on this one is chipping off and looks gross. I just want to make sure there's nothing else I should be ordering.
#188 Posted : Saturday, February 9, 2013 3:00:04 PM(UTC)
You may want to replace the ice maker first and see how it will perform. Post the results.
- The ice maker Part number: 2198597
mcdbones
#189 Posted : Thursday, February 14, 2013 2:12:04 PM(UTC)
mcdbones
replaced ice maker yesterday. today=no ice
Tested fill tube the other day when I first asked question and I could blow through it so I don't think it's frozen.
Wife sick of buying ice at store. I think the best valentines present I could give her is a working ice machine.:)
#190 Posted : Thursday, February 14, 2013 2:27:34 PM(UTC)
Perform the diagnosis as described in the attached file and post the results.
Here are the breakdown diagrams and Parts for Whirlpool KSCS25INSS00 Refrigerator - AppliancePartsPros.com
File Attachment(s):
In door ice system - component diagnostics.doc (167kb) downloaded 24 time(s).
Guest (10)
