Dish washer has 2 issues, first it does not always fill with enough water to run the jets. The second problem is it slowly drains during the wash and rinse cycles.
Hello,
Where is the drain hose connected to?
What is the complete model number of the dishwasher?
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hello,
Gene. Model # 665.1321 2k901 It goes through a hole in the floor to a drain line in the joists. Im going to rerought the drain to the garbage disposal to see if that helps. The only thing is this machine has ben installed and working properly for more than a year so i dont think thats the issue. Read more: http://forum.appliancepartspros...water.html#ixzz2Jm6xOcA7 http://forum.appliancepartspros.com
The drain hose should go at least 20" above the floor.
