gppaul
#1 Posted : Sunday, January 27, 2013 5:08:52 PM(UTC)
gppaul
We have water on the floor (small puddle) at the left front corner of the refrigerator. We just replaced the ice maker but had the same leak before we did this. We have leveled the refrigerator but this did not stop the leaking. Any suggestions.Thanks.
#2 Posted : Monday, January 28, 2013 4:51:50 PM(UTC)
Hello,
Very likely the cause of this water leak is a clogged/frozen drain in the freezer. The drain is located under the evaporator coils. Remove the rear cover in the freezer and defrost the drain using a hair dryer. Run some hot water through the drain using a turkey baster.
Pull the refrigerator out of the wall. Remove the cover and make sure the other end of the drain is clear as well.
GE GSHS9NGYBCSS Refrigerator Leaking and Not Cooling (Refrigerator & Freezer Repair)
by Wudman 1/13/2023 5:12:29 AM(UTC)
Refrigerator leaking after drain line is replaced. (Refrigerator & Freezer Repair)
by JustLooking72 9/22/2020 4:12:05 PM(UTC)
Refrigerator Leaking on the ice tray and front door (Refrigerator & Freezer Repair)
by RobertoS 8/2/2020 9:55:52 AM(UTC)
Whirlpool refrigerator leaks water (Refrigerator & Freezer Repair)
by timba 2/2/2020 2:09:49 PM(UTC)
Refrigerator Leaking inside (Refrigerator & Freezer Repair)
by iconracr 11/22/2019 8:15:56 AM(UTC)
GE Refrigerator leaks water (Refrigerator & Freezer Repair)
by low_lead 7/30/2015 2:04:37 PM(UTC)
GE refrigerator leaking water from bottom (Refrigerator & Freezer Repair)
by Raidem8 5/19/2015 10:50:03 AM(UTC)
Samsung Refrigerator leaking inside bottom of fridge area (Refrigerator & Freezer Repair)
by dpointer68 4/28/2014 7:03:27 PM(UTC)
Whirlpool refrigerator leaking water (Refrigerator & Freezer Repair)
by goosemasterkl 1/1/2014 8:14:42 AM(UTC)
Samsung refrigerator leaking water (Refrigerator & Freezer Repair)
by wendyjoe 5/27/2013 8:57:36 AM(UTC)
Samsung refrigerator leaking water on fresh food side (Refrigerator & Freezer Repair)
by TWAppliance 2/10/2013 11:16:13 AM(UTC)
Refrigerator leaking (Refrigerator & Freezer Repair)
by TomFrykman 1/22/2013 1:29:54 PM(UTC)
Refrigerator leaking on floor (Refrigerator & Freezer Repair)
by Qapla 12/31/2012 4:38:59 AM(UTC)
Kenmore refrigerator leaking (Refrigerator & Freezer Repair)
by rosesbjs 11/11/2012 11:11:53 PM(UTC)
Refrigerator leaking water (Refrigerator & Freezer Repair)
by swiss54 8/17/2012 5:19:43 PM(UTC)
