my turntable will turn if I turn it prior to starting the micro but only for a short time then stop. Why is my turntable not working
Groups: APP Team
Hi. You need to check two things: First check if the slot in the middle of the support is intact Part number: 5304440284
Then using the multimeter check if there is 120VAC to the turn table motor when the microwave is ON. If the proper voltage is present - replace the motor Part number: 5304440021
