arnieg
#1 Posted : Monday, February 25, 2008 7:37:54 AM(UTC)
arnieg
I have refrigerator door handles that I would like to replace. The attachment shows a bolt (30) attaching a bracket (29) to the handle to the door frame. However, the second page of the attachment shows a chrome bracket which appears to be fastened from a bolt coming from the inside of the door.
If that is true, I need some ideas on how to remove the shelving on the inside of the door in order to get to the bolt that holds the chrome bracket covering the door handle.
File Attachment(s):
Doorhandle.pdf (152kb) downloaded 24 time(s).
#2 Posted : Monday, February 25, 2008 6:42:29 PM(UTC)
Looks to me that the door handle mounting screw is covered with the door trim (#35 or #42) and the end cap (#29) just snaps on.
If this is not right and the screw is going from inside the door, I would recommend to forget about the new door handle. This fridge looks very old and the plastic door liner, most likely, is in bad condition.
arnieg
#3 Posted : Tuesday, February 26, 2008 10:48:31 AM(UTC)
arnieg
I wish it was that simple. If you look at the second picture, you can see four screw holes. The one on the left is for the screw that comes from inside the fridge and holds the cap. Only way to do this is to remove the door liner.
Thanks for responding.
Kirt
#4 Posted : Thursday, April 16, 2009 3:30:44 PM(UTC)
Kirt
My frig in in good condition. What should it cost to have an expert repair both handles? If too much, then I will forget it.
