lacoppari
#1 Posted : 12 years ago
lacoppari
For the past 15 years our dishwasher will not start unless the selector button for pots/pans is the one engaged. The other two washes are normal and china. I know the normal button does nothing. The rinse-hold button works properly.
When you press the normal button, the timer runs and you an hear the click as the cycles are indexed by the timer. The washer works fine if the pots/pans button is pressed. I cannot say anything about the china cycle as it is never used.
What do you think needs replacing? The big switch behind all the buttons for pots/pans, normal, china, heated drying, rinse hold, etc.
Any help would be appreciated. Thanks in advance.
A few minutes later: I was going by memory here but was running a test as I typed above. I had engaged the normal button. Nothing happened until the timer button got to china, then the dishwasher began filling. The timer was originally at the pots/pans location. It passed by the normal index position where the washer should have started making only an easily audible click. When it got to the china position it began the fill process. But it should have started at the normal position.
Simon / APP Team
#2 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
The key parts for this dishwasher is no longer available.
Sorry.
Simon.
lacoppari
#3 Posted : 12 years ago
lacoppari
But what is the problem? The switch or the timer?
But what about this?
http://www.********.com/itm/NEW...RT-4163547-/300565410339
lacoppari
#4 Posted : 12 years ago
lacoppari
But is it the timer or the switch that is the problem? I'm hoping someone can tell me so I don't have to go inside and investigate with a multimeter.
And what about this?
If you google the part number, you can find it on ********.
Bosch dishwasher does not start second cycle (Dishwasher Repair)
by Guest 3 years ago
Bosch dishwasher does not start washing (Dishwasher Repair)
by brokedishwasher 12 years ago
Kitchen Aid Dishwasher Does Not Start (Dishwasher Repair)
by eriewhaler 14 years ago
Dishwasher does not start (Dishwasher Repair)
by rsabbag 15 years ago
kitchenaid dishwasher does not start (Dishwasher Repair)
by daid schiffl 16 years ago
KitchenAid Dishwasher does not Start (Dishwasher Repair)
by fra 16 years ago
by Phillip Anderson 16 years ago
by dwnhll 16 years ago
by jmshareef 16 years ago
