3 Pages123>
tresor
#1 Posted : Monday, January 21, 2013 4:55:38 PM(UTC)
tresor
hi,
The machine spins slowly, not letting all the water out of the clothes.
We alreaty replaced the water pump, but still the same problem. There was also a slight burning smell after the last wash. It doesn't leak, no other issues.
Also, I'm attaching a photo of a part that we are not sure what it is and if it is normal. Looks like a brace of sorts that should be closed.?..but we have no idea. Couldn't find it on the website.
Any help would be sooo appreciated. thank you!
maria
tresor attached the following image(s):
#2 Posted : Tuesday, January 22, 2013 3:48:04 PM(UTC)
Originally Posted by: tresor Go to Quoted Post
...The machine spins slowly, not letting all the water out of the clothes.
We alreaty replaced the water pump, but still the same problem...
...Also, I'm attaching a photo of a part that we are not sure what it is and if it is normal. Looks like a brace of sorts that should be closed.?..but we have no idea. Couldn't find it on the website...
Hi Maria,
The slow spin (wet clothes) could be caused by: unbalanced load; a clogged hoses to and from the drain pump; a bad drive block (#10 at the diagram); a bad basket drive (#1 at the diagram) or a bad clutch (#5 at the diagram). You can find more information in one of our previous threads: http://forum.appliancepartspros...ir/373-not-spinning.html
- The drive block Part number: 389140
Part number: 389140
- The spanner wrench (needed to access the drive block) Part number: TJ90TB123A
- The basket drive Part number: 285792
Part number: 285792
- The clutch assembly Part number: 285785
Part number: 285785
The part on your picture is the suspension spring. It looks not so bad and I don't think it needs any attention so far.
Here are the breakdown diagrams and Parts for Whirlpool LC4900XTW0 - AppliancePartsPros.com
tresor
#3 Posted : Tuesday, January 22, 2013 5:50:20 PM(UTC)
tresor
hi Gene,
Thank you so much for this info. Should we replace all these parts, one at a time to see which is the true culprit? Which would you start with?
On the suspension springs, should those braces at the base be "closed" somehow?
I so appreciate all your help.
maria
Hi Maria,
Part number: 389140
Part number: 285792
Part number: 285785
#4 Posted : Tuesday, January 22, 2013 9:24:28 PM(UTC)
Replacing parts without proper troubleshooting is wasting of money and time. I would suggest to open the thread I posted for you and read all instructions.
fairbank56
#5 Posted : Wednesday, January 23, 2013 5:27:38 AM(UTC)
fairbank56
The clamp laying loose on the bottom are used during shipping. The springs are compressed, the clamp is closed to hold them in the compressed position and a key is installed to keep the clamp from opening. Straps are attached to the keys and the straps are positioned up over the top and down into the tub. During initial installation of the washer, you open the lid, yank on the three straps to pull the keys out to release the clamps which releases the springs.
Eric
tresor
#6 Posted : Thursday, January 24, 2013 2:39:40 PM(UTC)
tresor
Thank you, Eric! I appreciate this answer.
tresor
#7 Posted : Thursday, January 24, 2013 2:42:47 PM(UTC)
tresor
I watched the video on replacing the clutch, but did not see an example of what a 'bad' clutch looks like. Does anyone have a description or a photo? What evidence to look for to know that the clutch is bad and needs replacing?
thank you!
#8 Posted : Thursday, January 24, 2013 2:54:45 PM(UTC)
Did you check the drive block and the basket drive tube yet?
Did you see any signs of leaked oil?
tresor
#9 Posted : Thursday, January 24, 2013 2:57:03 PM(UTC)
tresor
There are no signs of leaking oil.
#10 Posted : Thursday, January 24, 2013 3:15:32 PM(UTC)
What about this question?
Guest (9)
Slow spin - clicking drum (Washer Repair)
by Machine_Slo 1/6/2020 9:18:40 PM(UTC)
Noise during the fast spin cycle, but not slow spin cycle (Washer Repair)
by onthego4858 6/17/2017 10:18:24 AM(UTC)
Slow spin cycle (Garbage Disposer Repair)
by Cbus 4/26/2016 11:35:11 AM(UTC)
Whirlpool top load very very slow spin (Washer Repair)
by Docken 10/22/2014 5:31:26 PM(UTC)
Intermittent stuck on slow spin (Washer Repair)
by pmhstar 4/28/2014 10:58:36 AM(UTC)
No agitation and clicking during slow spin (Washer Repair)
by Whirlpool ray 12/6/2013 8:54:59 PM(UTC)
Whirlpool top loader slow spin cycle (Washer Repair)
by Re Vera 6/24/2013 12:34:34 PM(UTC)
Intermittent Slow Spin (Washer Repair)
by imageshift 4/2/2013 8:49:27 AM(UTC)
by twg2 4/26/2012 7:40:43 AM(UTC)
No spin or slow spin (Washer Repair)
by Morrisp 10/17/2011 1:02:27 PM(UTC)
slow spin and noisey in rinse cycle (Washer Repair)
by indoorairpro 9/25/2011 8:34:40 AM(UTC)
Leak & Slow Spin (Washer Repair)
by 4evrmoor 4/20/2011 9:14:26 AM(UTC)
Maytag Performa washer, slow spin speed (Washer Repair)
by hank b 4/18/2011 7:26:54 AM(UTC)
by edtrade 3/11/2011 3:15:35 AM(UTC)
Maytag washer slow spin (Washer Repair)
by Handyman3 1/25/2011 7:14:40 AM(UTC)
3 Pages123>
