2 Pages<12
richappy
#11 Posted : Friday, December 14, 2012 7:54:43 AM(UTC)
richappy
The BEST stuff I ever found was at Walmart non-residue contact cleaner by CRC $4.95, so "liquid" it will penetrate any small opening and displace oil and contaminents.
bigalp45
#12 Posted : Saturday, January 19, 2013 7:18:22 PM(UTC)
bigalp45
Rank:: Member
I ended up changing the cold control but I have noticed that the refrigerator has run for about 6 hours straight. It was a pretty easy install, is it possible that I did something wrong or is this normal? Maybe it could be the defrost timer???
richappy
#13 Posted : Sunday, January 20, 2013 12:25:02 AM(UTC)
richappy
As lons as you routed the sensing tubing from the control exactly were the old one was, you should be ok. If the fridg was warm, it takes up to 12 hrs to reach temperature.
bigalp45
#14 Posted : Tuesday, January 22, 2013 7:40:53 AM(UTC)
bigalp45
Rank:: Member
The system is cycling on and off now but the refrigerator seems a lot colder than before. Previously to changing the cold control, I had the temperature setting at "3" out of a possible 1 to 5, I now have it set below "1" and the refrigerator still seems colder than it should be. It just seems to be running more than is needed.
richappy
#15 Posted : Tuesday, January 22, 2013 2:48:21 PM(UTC)
richappy
The fridg temperature should ba around 41 degrees.
richappy
#16 Posted : Saturday, February 2, 2013 8:01:29 AM(UTC)
richappy
Check the freezer temperature, should be lower than 5 degrees if running a lot.
bigalp45
#17 Posted : Sunday, February 3, 2013 4:31:46 AM(UTC)
bigalp45
Rank:: Member
I still need to get a refrigerator thermometer. Thanks!
GE monogram zisb360dri refrigerator problem (Refrigerator & Freezer Repair)
by aryehsternman 10/11/2020 5:18:56 PM(UTC)
Kitchenaid refrigerator problems (Refrigerator & Freezer Repair)
by Kendug 8/12/2020 7:40:47 AM(UTC)
Refrigerator problem (Refrigerator & Freezer Repair)
by Janet P. 5/22/2015 7:29:28 AM(UTC)
Refrigerator Problems (Refrigerator & Freezer Repair)
by thshen34 12/9/2014 7:17:28 AM(UTC)
Whirlpool refrigerator problem - Ideas? (Refrigerator & Freezer Repair)
by RMO87 2/8/2014 2:24:24 PM(UTC)
Kenmore Coldspot refrigerator problem (Refrigerator & Freezer Repair)
by repair123 8/20/2013 3:05:06 AM(UTC)
Kenmore side by side refrigerator problems (Refrigerator & Freezer Repair)
by suespoppy@aol.com 3/11/2013 11:17:56 PM(UTC)
by suespoppy@aol.com 3/11/2013 10:33:57 PM(UTC)
Kenmore refrigerator problem (Refrigerator & Freezer Repair)
by Nate H 10/25/2012 6:11:42 PM(UTC)
frigidaire refrigerator problem (Refrigerator & Freezer Repair)
by ricksfund85 6/25/2012 9:14:37 AM(UTC)
GE Profile Refrigerator Problem (Refrigerator & Freezer Repair)
by six_pack 4/5/2012 7:34:56 PM(UTC)
Kenmore (Amana) Refrigerator Problems (Refrigerator & Freezer Repair)
by JDB59 12/26/2011 10:31:56 AM(UTC)
by duff1234 9/2/2011 6:58:39 AM(UTC)
Refrigerator problem, Need help please. (Refrigerator & Freezer Repair)
by jbyoung 8/9/2011 3:52:06 PM(UTC)
GE Refrigerator Problems (Refrigerator & Freezer Repair)
by phx1hab 6/17/2011 7:41:09 AM(UTC)
2 Pages<12
