AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Kenmore front load washer dies before end of cycle.
When it gets to the spin, (usually), it will only run maybe a minute, Then the whole machine shuts down(no lights on display), and even the door stays locked unless I power it all up again.
What could be the cause of it comeletly shutting down??
Thanks.
Even if I put it on rinse spin, it starts to work for maybe a minute, then just shuts down, as if it got unplugged from the power, and the door is still locked also.
It now just completely dies anywhere on any cycle. Can someone please help ?? Could it be the front control panel, or the upper right control board maybe??
Thanks.
Couldn't find an answer. Machine has now been replaced for another washer.
Washer Repair
