:confused: I replaced the overload relay and the start capacitor because it was buzzing and the fridge/freezer quit working. It's still showing the same symptoms...buzzing just the way it was before, but it feels like the coolant lines from the compressor are starting to chill, I'm not sure how long I should give it and does this mean the compressor is shot? :(
You have either a hard starting compressor, or power problems at the outlet. If you have a meter, you could check the voltage, but most of the time it's just a bad compressor, amprobe would confirm.
