Dbrod
#1 Posted : Thursday, January 10, 2013 7:56:11 PM(UTC)
Dbrod
Can you tell me what the part Number for the valve is or better yet, link me to it? Thanks.
The cold water constantly runs.
#2 Posted : Friday, January 11, 2013 5:19:33 PM(UTC)
Hello,
The model number you posted is incorrect. Verify and repost it please.
Dbrod
#3 Posted : Saturday, January 12, 2013 8:24:01 AM(UTC)
Dbrod
The model number is WPGT9360E0WW
#4 Posted : Saturday, January 12, 2013 8:33:11 PM(UTC)
Thank you.
The water inlet valve Part number: WH13X10017
Here are the breakdown diagrams and Parts for GE WPGT9360E0WW Washer - AppliancePartsPros.com
Dbrod
#5 Posted : Sunday, January 13, 2013 6:20:52 PM(UTC)
Dbrod
Thanks for the intel.
I've been using the machine because the laundry never stops around here. I've just been shutting off the water at the wall during the last drain cycle. What I noticed today was when I went to the washer during the last drain cycle, the water had stopped running. Is it bound to fail again or mightily be okay for a while?
#6 Posted : Monday, January 14, 2013 1:18:46 PM(UTC)
Originally Posted by: Dbrod Go to Quoted Post
...Is it bound to fail again or mightily be okay for a while?...
Most likely yes. But if it's fine now, do not replace the part yet. You can order it and keep it in case if it will start again. You have 365 days to return the part.
