Both the oven burner and the broiler burner will not light. The oven ignitor does not seem to come on at all. The broiler glows bright orange but still doesn't light. No gas comes out in either situation. Could a bad oven ignitor cause the broiler not to work too or is there another problem behind this? I am going to get a new ignitor and try that but if anyone has any ideas in the meantime please let me know. Thanks.
Most likely the both (bake & broil) igniters are bad. You can replace one at a time or both together. - The part number for the oven igniter (bake & broil) AP2014008 Gene.
Thanks for the quick reply. Much appreciated. Is it just a coincidence that they both went bad at the same time? If I replace just the oven one first will that allow the oven to light up or do they both have to be good for either one to work?
They are absolutely independent.
