rogerd1961
#1 Posted : Thursday, December 27, 2012 3:18:45 PM(UTC)
rogerd1961
I have a Roper dryer model number REX4634JQ0 with no heat. I purchased a heating element from appliancepartspros.com. I installed it, still no heat. I then purchased a thermal fuse and cycling thermostat. It heated really well for one load, then no heat again. I then purchased the high temp thermostat that mounts to the heating element, and the thermal cut off, and still no heat. All parts were purchased from appliancepartspros.com, and the last two parts were purchased at the recommendation of a live chat expert. Any ideas? Thank you.
Simon / APP Team
#2 Posted : Thursday, December 27, 2012 5:18:50 PM(UTC)
Simon / APP Team
Groups: APP Team
HI.
Does the motor run?
Is there a 240VAC to the dryer?
I really suggest you to get a simple multimeter so you'll be able to check the parts before replacing them.
Simon.
Bernie Bernal
#3 Posted : Friday, December 28, 2012 5:06:20 AM(UTC)
Bernie Bernal
Dryer heats on intial start but then will shut off and not heat anymore, will continue to run and dial will not time out. So far replaced dryer timer dial, thermal fuse & dryer cycling thermostat, I also vacumed out exhaust vent! What next? I should have purchased a continuity tester!
Bernie Bernal
#4 Posted : Friday, December 28, 2012 5:26:55 AM(UTC)
Bernie Bernal
Originally Posted by: Simon / APP Team Go to Quoted Post
HI.
Does the motor run?
Simon.
Yes the motor runs and the blower is working fine!
Simon / APP Team
#5 Posted : Friday, December 28, 2012 10:11:13 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Bernie.
The questions I'd posted were not addressed to you.
You have a gas dryer and it sounds like the control coils should be replaced Part number: 279834
Part number: 279834
Here are the breakdown diagrams and 8318272 Burner Assembly parts for Roper RGX4634KQ2 - AppliancePartsPros.com
Post the results.
Simon.
Bernie Bernal
#6 Posted : Sunday, December 30, 2012 5:39:37 AM(UTC)
Bernie Bernal
Hi, Bernie.
Part number: 279834
Post the results.
Simon.
Many thanks Simon! Replaced the control coils and now the dryer works perfectly!
Simon / APP Team
#7 Posted : Monday, December 31, 2012 2:16:37 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
roper dryer no heat (Dryer Repair)
by chuck vaughn 12/1/2014 1:35:50 PM(UTC)
Roper Dryer No Heat Problem (Dryer Repair)
by schmocker 7/16/2012 1:17:00 PM(UTC)
