We set the oven to bake at 350 and it warms to 350. Then it beeps that its ready. We hear no fan turning. Then it may climb to higher temps and we keep pushing the buttons to get it back to 350. It may start dropping in temp below 350. Eventually the display goes out and the heat goes away too. We wait a few minutes and it eventually comes back on. From previous threads it sounds like the thermostats?
Groups: APP Team
Hi. Most likely the problem is the control board/clock. It's no longer available. Check the oven sensor resistance first (1100ohm at room temperature) and if it's checks out OK - then it is the control board. Oven sensor Part number: 31968201
The control Part number: 31944801
Yo can try the internet to look for the place who may rebuild the old clock for you. Simon.
