2 Pages<12
Eric_koski
#11 Posted : Friday, December 14, 2012 9:51:34 AM(UTC)
Eric_koski
UPDATE: the ticking noise when running is coming from the board on the control panel. Any ideas??
Eric_koski
#12 Posted : Friday, December 14, 2012 10:15:43 AM(UTC)
Eric_koski
Appears to be Omron 24VDC relay on control board. Ideas?
#13 Posted : Friday, December 14, 2012 5:25:57 PM(UTC)
So, the new control board should fix it. Hopefully the magnetron is still good because my suggestion about it was based on the noise from the above of the control panel. The magnetron is sitting there.
Eric_koski
#14 Posted : Friday, December 14, 2012 5:49:22 PM(UTC)
Eric_koski
Yeah I figured the board was bad. The sound seemed to come from the back but I pulled the unit and powered it with the cover removed. I could feel the relay making noise. Also checked diode while it was apart. Thanks for your help.
Happy holidays!
#15 Posted : Friday, December 14, 2012 6:29:05 PM(UTC)
Happy Holidays to you as well!
Keep us posted.
Eric_koski
#16 Posted : Wednesday, December 26, 2012 8:19:24 AM(UTC)
Eric_koski
Back to square one again! I replaced the control board and no luck. Still shuts off after 3 sec. What to do now?
#17 Posted : Wednesday, December 26, 2012 4:11:46 PM(UTC)
Sorry to hear it.
Does it make the same noise too? Does the fan work?
Eric_koski
#18 Posted : Wednesday, December 26, 2012 5:05:02 PM(UTC)
Eric_koski
Yeah same noise from relay on the board. Fan works also. I have checked door switches, diode, thermal cut switch, ohmed the magnetron. Need new ideas.
#19 Posted : Thursday, December 27, 2012 12:02:17 PM(UTC)
Very strange situation. Try to replace the magnetron. If it would not fix the problem then you can return it.
Guest (5)
2 Pages<12
