MODEL: Maytag MFD2561HES
Issue: The refrigerator runs continually because there isnot thermal sense into the PC board to turn off the compressor. The temperature of the refrigerator is belowthe setting. What part or parts would beneeded to resolve this issue?
Thanks!
You might have system problems. Measure the stabilized freezer temperature and post, also check for frost on the back freezer panel.
It looks like thermistor in the refrigerated section of refrigerator is not accurate. I am going to replace that and see if issue resolved. Thanks
The thermistor came in today, but am having issue trying to figure out how to open the interior control board to get to the thermistor. I do not see any screws. Any insight would be appreciated.
I can see no screws, but you can use a putty knife and carefully pry out the housing. Helps to have the housing warm.
