Hi, I'm having an unknown problem with my Bosch Axxis WAS20160UC. It was working fine one minute then the next I can't get it to spin at all. Checked the belt (OK) and the motor (OK no black grit). Does anyone know how to put this model into diagnostic mode to do tests or have the fault codes? At one point I got the regular spin, spin, and end flashing but it doesn't do that now.
Hello, Perform the tests as instructed in the attached file and post the results. Gene.
Thanks so much Gene, that was exactly what I needed (and more). I'll run the tests tonight when I get home for work and post the results.
I'm having a similar problem and have error 67 flashing - "Implausible or inexistent variant coding", but I haven't played with setting any variants. Any hints on what's wrong or needs to be replaced? Do the variants need to be reprogrammed after replacing the operating or power module? Perhaps did my unit get reset and it just needs reprogramming?
Hi I have the same washer. I replaced the main control PCB and not the hot water doesnt work. Does anyone know how to program the washer
