dclange
#1 Posted : Tuesday, December 11, 2012 3:29:17 PM(UTC)
dclange
Model GSS25JEMACC, GE March, 2001
Quit cooling. The Evaporator and Condenser fans both run, lights work. The compressor will not kick on. Pulled off the overload and start relay and run a couple test on compressor. Did a continuity test between all three pins on compressor, meter buzzed on all three combinations, so passed that test. Checked all three pins to ground, no continuity, passed that test. Did an Ohms test, top pin to bottom left 3.6 ohms, top to bottom right 4.7 ohms, bottom left pin to bottom right pin 7.9 ohms. I'm thinking these measurements are within range and the compressor is good, I'm I correct? Tested the overload and relay both for continuity, both pass. The overload rattles when you shake it . No parts fall out and it does not look burnt. Is it still bad if it rattles? Looked at main board, everything looks look, can you test it? What should I try, new overload? Any other test I can run? Looking for help, please.......
richappy
#2 Posted : Wednesday, December 12, 2012 12:24:28 AM(UTC)
richappy
Take a picture of the wires to the start device WR07X10025 then order it on this site.
dclange
#3 Posted : Wednesday, December 12, 2012 8:22:28 AM(UTC)
dclange
Thanks for the reply Richappy! I will order the parts today from this site. Still, just curious if I did the testing right, are the readings on the compressor within range, the test good? The compressor is still good right? Thanks again.......great site!
PS: Should I also replace the "Overload" (WR08X10026) while I'm at it, are do you think it is just the start device alone that is the problem?
dclange
#4 Posted : Wednesday, December 12, 2012 1:59:30 PM(UTC)
dclange
Hello?????
richappy
#5 Posted : Thursday, December 13, 2012 12:17:37 AM(UTC)
richappy
The klixon overload is ok, don't need to change it. The compressor winding resistance readings show they are not blown open and are usefull in determing which is the start and run winding, and nothing else, do not assume they are not burnt or have shorted turns.
dclange
#6 Posted : Thursday, December 13, 2012 7:18:50 AM(UTC)
dclange
Thank you for repling. The start device has been ordered and is on its way. When it gets here, I will install and let you know what happens! ;)
dclange
#7 Posted : Saturday, December 15, 2012 7:11:17 AM(UTC)
dclange
Ok, received start device, installed on frig, zip, nothing. Lights and both fans still work, but still no compressor. So not the start device. From reading this forum, I figured take a look at the main board. Front of board looked fine, no burnt marks are anything. Took the two bottom wire harnesses loose from the main board and released the four little pins holding the board on, (left the other four wire harnesses connected) and tilted the board up so I could see the back side of it. Found a burnt solder joint! Looking at the front of the board, it looks like the burnt joint is right under where the compressor relay is mounted to the front of the main board. Just guessing here, but it looks like I need a new board huh?
richappy
#8 Posted : Sunday, December 16, 2012 1:11:16 AM(UTC)
richappy
Probably best to order a new board WR55X10942 if you have no soldering experience.
Guest (6)
