frankhvac@yahoo.com
#1 Posted : Tuesday, December 11, 2012 7:32:12 PM(UTC)
frankhvac@yahoo.com
washer fill light comes on but no water ....checked voltage to solenoid valves found 0 volts...lid switch light comes on....washer inoperable ....
Simon / APP Team
#2 Posted : Wednesday, December 12, 2012 12:17:46 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
First check the water level switch. The contacts 1 - 3 should be open(no continuity) Part number: W10268911
If it's closed - clear the air hose (blow in to it) and if that doesn't help - replace the switch.
Check all the connections to the control board.
On the side of the washer cabinet find the manual and perform the test.
Possible the main board should be replaced, but don't just replace it run the test first.
Here are the breakdown diagrams and Controls and Water Inlet parts for Whirlpool WTW4800XQ1 - AppliancePartsPros.com
Post the results.
Simon.
