Parts for Whirlpool LER3622HQ1 Dryer - AppliancePartsPros.comSee the attachment for the wiring diagram
[COLOR="Blue"]I just ordered a thermal fuse on this site, is my best bet to replace that and if it works, see if I have another failure before replacing something else?[/COLOR]
Since the vent system checks out OK I would spend some time and try to find out why the fuse blew.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the fuse blows.
The hi-limit should have regulated the temperature so the fuse did not blow.
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut)
Use a meter scale that is sensitive enough to give you a mid scale reading. If such a scale is available.
When you expect 0 ohms use the most sensitive scale.
I cannot help much on your meter readings as I have not used an analogue meter is over 20 years.
It should give you a steady reading.
Below is info on meter usage.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset. I think you zero the needle using the adjustment just under the meter face on an analogue meter.
