2 Pages<12
keitort
#11 Posted : Sunday, December 9, 2012 12:21:56 PM(UTC)
keitort
Hello. Reading thru this forum and I am having the same problem it appears. My Roper dryers heat will come on but just for a minute or two. Everything else appears to be working. i.e. timer, motor,etc. I have checked all the switches (high limit, cycling thermostat)with a ohm meter and all have continuity. Heating element checks ok and does not read that it is grounded out. Checked timer by testing black-blue connections. All is good. Vent is free of lint from unit all the way to outside. Driving me crazy. :confused:
#12 Posted : Monday, December 10, 2012 11:07:38 AM(UTC)
keitort
Start a new thread using "POST NEW TOPIC"
Be sure to include the make and model number.
Adding to this post about a different model will just confuse things.
Also more detail on the problem.
Does it do this on full heat only or also on low heat?
Does the heat come back on later or does it shut off and stay off?
etc.
Guest (6)
2 Pages<12
