Davejb
#1 Posted : Sunday, December 9, 2012 2:46:32 PM(UTC)
Davejb
Dryer won't start (110 volt light works) after removing lint by:
1 Disconnect power and open top
2 Removed front panel
3 Disconnect 5 wires (took photo before removing wires) from front panel
4 Vacuumed what I could reach by having front off
5 Pulled away from wall
6 Vacuumed duct going into basement
7 Vacuumed duct in dryer
8 Generally cleaned/vacuumed/washed whatever I could reach
9 Reassembled - being careful to get 5 wires reconnected to correct terminals - double checked, they are :)
10 Light works, motor will not start.
Was working perfectly before the lint removal project.
:confused: :confused:
Appreciate any suggestions
#2 Posted : Monday, December 10, 2012 10:35:58 AM(UTC)
Parts for Frigidaire GLER341AS2 Dryer - AppliancePartsPros.com
Here is a wiring diagram
http://manuals.frigidaire.com/p...df/Webster/131850600.pdf
Light is on but does is go off when the door is closed?
You will just have to check your wiring.
Also check for any loose/pulled off wires at the timer.
If you cannot find the open then you will need a meter to track it down.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Davejb
#3 Posted : Monday, December 10, 2012 10:55:52 AM(UTC)
Davejb
Originally Posted by: denman Go to Quoted Post
Thx for the reply-
Light switch checks OK with VOM as does door switch. The wiring diagram (have the one that came wth the dryer) does not agree with my machine. On my dryer, the "Control Thermostat" has 4 terminals per the diagram, but the 2 right hand are not shorted together (at the switch, anyway - they may be elsewhere)
I assume any switch/thermo having to do with too much heat are not at issue. Mistake?
Also, how can I check the motor - coil resistance, switches, etc.?
Davejb
#4 Posted : Monday, December 10, 2012 11:34:04 AM(UTC)
Davejb
Don't see how to post another reply - but I reassembled unit and it works. Makes no sense. But appreciate the professional support nonetheless.
Thx again.
Davejb
g8tordave (Refrigerator & Freezer Repair)
by g8tordave 6/24/2013 1:31:47 PM(UTC)
Davepark (Washer Repair)
by Davepark 2/18/2012 7:24:59 AM(UTC)
dave repairs (Oven Repair (including Ranges and Cooktops))
by dave repairs 2/13/2010 5:26:01 PM(UTC)
dave (Oven Repair (including Ranges and Cooktops))
by dp16 12/26/2009 9:21:31 PM(UTC)
DAve (Dryer Repair)
by rossdr 9/26/2009 9:17:59 AM(UTC)
Dave Sheridan (Oven Repair (including Ranges and Cooktops))
by DAVID SHERIDAN 8/20/2009 1:18:08 PM(UTC)
Dave (Oven Repair (including Ranges and Cooktops))
by Dave 5377 7/19/2009 2:14:54 PM(UTC)
by bigwavedavejtx 3/10/2009 4:21:48 PM(UTC)
GE Spacedaver Microwave turntable out (Microwave Repair)
by lisalaughery 2/26/2009 8:40:27 PM(UTC)
Dave (Dryer Repair)
by jonesdt 9/15/2008 9:00:25 AM(UTC)
by dave.welsh 7/31/2008 3:50:24 AM(UTC)
Dave H (Microwave Repair)
by dave holmdahl 1/18/2008 3:08:15 PM(UTC)
dave baker (Dryer Repair)
by dbaker04 10/29/2007 3:21:35 PM(UTC)
Dave P. (Heating, Ventilation, and Air Conditioning (HVAC))
by Batman Dave 9/13/2007 3:21:17 PM(UTC)
