Ann Bales
#1 Posted : Wednesday, November 28, 2012 8:40:48 AM(UTC)
Ann Bales
Hello, My freezer completely gets covered in ice and has to be manually defrosted. It then works fine for about a week or two, then it freezes up again.
I read in a forum once that the side by side defrost heater is not large enough for the system and should be replace with a 2 piece unit. Is this maybe correct?
Thanks Ann:confused:
richappy
#2 Posted : Friday, November 30, 2012 5:05:55 AM(UTC)
richappy
Yes, your single element defrost heater is probably bad. If it's black inside with a gap, that confirms it. Order a new one here.
