HkyFrk
#1 Posted : Monday, November 26, 2012 7:37:58 AM(UTC)
HkyFrk
I kept on smelling gas while the oven was on so I figured I had an ignitor that went.. I replaced no problem... (thanks guys)
It worked for some time now, but I seem to have got another problem. There is too much gas being released in the oven when I first put it on. I motly hear a big whoosh and some times the door pots a bit. Is it the ignitor, the gas safety valve or something else. Any help would be appreciated
#2 Posted : Monday, November 26, 2012 4:13:45 PM(UTC)
Hello,
There are two igniters in the oven: Bake and Broil. Which one and when did you replace?
Here are the breakdown diagrams and Parts for GE JGS968SH3SS Range - AppliancePartsPros.com
HkyFrk
#3 Posted : Monday, November 26, 2012 7:21:14 PM(UTC)
HkyFrk
Thanks for the quick reply
It was the lower one I believe the bake one
#4 Posted : Tuesday, November 27, 2012 2:40:40 PM(UTC)
Visually inspect the bake burner for any blocked and/or burned through flame holes. Make sure the igniter is properly aligned with the burner lighting holes.
If there is nothing wrong then most likely the igniter is bad.
- The oven igniter Part number: WB13T10045
HkyFrk
#5 Posted : Tuesday, November 27, 2012 6:40:13 PM(UTC)
HkyFrk
Silly question..... How should they be aligned?
#6 Posted : Tuesday, November 27, 2012 7:05:50 PM(UTC)
The igniter and the burner tube should be parallel.
HkyFrk
#7 Posted : Tuesday, November 27, 2012 8:01:46 PM(UTC)
HkyFrk
Ok....... Thanks
If it is the igniter that is the problem, what could the issue be that the igniter keeps on "going"?
What could I check next?
Thanks for all your help!
#8 Posted : Wednesday, November 28, 2012 5:50:53 PM(UTC)
Originally Posted by: HkyFrk Go to Quoted Post
...what could the issue be that the igniter keeps on "going"?...
I have no idea. Average live time for oven igniter should be 2-3 years or even more.
HkyFrk
#9 Posted : Thursday, November 29, 2012 7:42:01 AM(UTC)
HkyFrk
thanks...
I would like to check the amps to the ignitor. Are the wires to the ignitor accessible from underneath the stove or only from the back on this model?
#10 Posted : Thursday, November 29, 2012 11:38:12 AM(UTC)
Remove the oven floor and the flame spreader. You probably did it before when you replaced the igniter?
The normal reading should be more than 3.2 amps.
Guest (7)
