darrell38
#1 Posted : Wednesday, December 5, 2007 10:32:26 AM(UTC)
darrell38
My Maytag washer will not stop flowing washer into the tub. It will not spin or rinse, when placed on the setting for each.
#2 Posted : Wednesday, December 5, 2007 2:43:07 PM(UTC)
The first thing I would check is the connection of the air tube to the water level switch (#13 on the control panel break down diagram).
If it got loosen, drain all water out before reconnecting.
If there is nothing wrong then the water level switch is bad.
- The part number for the water level switch AP250430
- Here are the break down diagrams for the Maytag washer Model LAT9406AAE
darrell38
#3 Posted : Wednesday, December 5, 2007 7:52:09 PM(UTC)
darrell38
The washer will only fill up, it will not work in spin or rinse cycle. The water level switch is working. I put it in mini load and it fills to the proper level and shuts off. It will not continue the cycle and wash the clothes. i am thinking the timer is bad. It has not moved from the position that I placed it in earlier today.
#4 Posted : Thursday, December 6, 2007 9:52:10 AM(UTC)
In such situation I would check the lid switch first.
You can find complete instructions in the service manual (page 3-14).
