cwbigfish
#1 Posted : Wednesday, November 7, 2012 8:19:55 AM(UTC)
cwbigfish
My Estate dryer has suddenly started acting weird. The heat isn't working all the time and the dryer will run when timer is in off position. I checked the back of the knob for stripping and cracking but all seem OK. I'm pretty sure its a timer issue but before I spend 3/4 the cost of the dryer for a new timer I want to be sure, any help appreciated.
Simon / APP Team
#2 Posted : Wednesday, November 7, 2012 11:50:36 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Use the multimeter to check the timer contacts. With the timer set for Timed - Regular and power off check the contacts T-F, C-B, C-A for continuity. Then turn the timer to OFF and check again. If there is continuity at any of this contacts with the timer off - replace the timer
Part number: W10185970
Here are the breakdown diagrams and Top and Console Parts parts for Estate EED4400WQ0 - AppliancePartsPros.com.
Post the results..
Simon.
cwbigfish
#3 Posted : Friday, November 9, 2012 6:03:57 AM(UTC)
cwbigfish
thanks...gonna try that!
Simon / APP Team
#4 Posted : Friday, November 9, 2012 10:14:11 AM(UTC)
Simon / APP Team
Groups: APP Team
Keep us posted.
Simon.
cwbigfish
#5 Posted : Friday, November 9, 2012 11:38:48 AM(UTC)
cwbigfish
I had no continuity between C A with with power off and selector set to regular. Had continuity between C B with selector in off position. I take it the timer is the issue?
Simon / APP Team
#6 Posted : Friday, November 9, 2012 1:38:01 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Replace the timer.
Simon.
Guest (5)
