TWISTEDKEVIN
#1 Posted : Wednesday, December 5, 2007 3:30:59 PM(UTC)
TWISTEDKEVIN
My agitator only works when I fill the washer to a large wash load. If I fill it to a super load the bearings or something get wet and the top slips. I want to buy a new agitator, but I cant figure out how to get the old one out. Can anyone help me out with this problem? GE PROFILE MODEL# WPSR3100W2WW
Thank you,
TWISTEDKEVIN
#2 Posted : Wednesday, December 5, 2007 4:25:09 PM(UTC)
Remove the dispenser assembly from the agitator and unscrew the bolt holding the agitator (#301 on the tub and agitator break down diagram).
The problem could be a worn out agitator coupling (#310 on the same break down diagram).
- The part number for the agitator coupling AP3964635
- Here are the break down diagrams for the GE washer Model WPSR3100W2WW
TWISTEDKEVIN
#3 Posted : Wednesday, December 5, 2007 5:17:54 PM(UTC)
TWISTEDKEVIN
Thank you for your time Gene, But the agitator coupling seems to be working great. It's the top of the agitator that slips and does not go round & round, it just goes back & forth, if I fill it to high. I removed the dispenser and saw no nut, It's a sealed part. The agitator has to be removed in order to get to the bolt you talked about. I to thought it should be that easy! It's NEVER that easy is it? Could it just pull up and out?
Thank you,
TWISTEDKEVIN
#4 Posted : Wednesday, December 5, 2007 5:22:44 PM(UTC)
In that case you just have to pull it up. It could be Very Hard!
TWISTEDKEVIN
#5 Posted : Wednesday, December 5, 2007 5:26:08 PM(UTC)
TWISTEDKEVIN
Do I just use my hands?
#6 Posted : Wednesday, December 5, 2007 5:34:06 PM(UTC)
It use to be a special tool, called "Agitamer". I'm afraid it's no longer available.
TWISTEDKEVIN
#7 Posted : Wednesday, December 5, 2007 5:42:25 PM(UTC)
TWISTEDKEVIN
Thank you again for your time, I think I'll order the part and see what it looks like and try to get it out. If it works I'll let you know how I did it, maybe I'll use a tool called pounditout. Wish me luck!!
From cold Cleveland Ohio
TWISTEDKEVIN
how do i remove the agitator from the tub (Washer Repair)
by gaylynn 4/8/2009 9:51:20 AM(UTC)
