How do we take out the control panel display for our double oven? After removing some screws, it looks like our oven may have the control panel display connected to the oven itself.
Any diagrams or instructions will be most helpful.
I am having the same problem trying to get to the control board. The oven in the pictures of the above attachment do not match my oven. I read on another forum that the whole oven may need to be pulled out to get the control panel off, can anyone confirm this. thanks
Originally Posted by: beebop ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ...that the whole oven may need to be pulled out to get the control panel off... It may help if you will pull the oven out for 10"-12". You don't have to pull it out completely. Gene.
For anyone else who may have this oven here are some clarifying steps to get to the control board. Remove the trim screws and trim remove screws that hold oven to enclosure(cabinet) pull oven out a bit (maybe 1/2 inch) and on either side of the control panel are 2 screws that need to be removed, then lift up to get the control panel over the tabs and then outward. the problem i now run into is that i cannot get the control panel out far enough to disconnect the wires. I am wondering if, like the previous post says, i need to pull the oven out more. Maybe there is a plate on the top that comes off for better access? beebop attached the following image(s):
Originally Posted by: beebop ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ...I am wondering if, like the previous post says, i need to pull the oven out more. Maybe there is a plate on the top that comes off for better access?... You will never know until you try. Gene.
