the detergent dispenser door will not open during wash cycle.
Can you open it manually?
What is the end of the model number?
I have a Bosch SHX46A05UC/14 that had a similar problem. My wife affected a work around of placing the soap cube in the holder and only closing the door half way. This worked but the real fix was me popping the door off and re-positioning the spring latch. It has worked great for years afterward. Until the CRTL panel quit last week... Bosch Dishwasher Repair: Dispenser Lever Replacement (part #166630) - YouTubeThe video shows servicing the dispenser but you should just have to re-position the spring and pop the door back on.
