bobgjr
#1 Posted : Thursday, November 1, 2012 5:50:17 AM(UTC)
bobgjr
Right front burner will not heat and the element on indicator light stays on all the time. Checked the element itself and it tests good. I'm thinking either the element switch or the thermal switch or both. Not sure how to check these two parts out. Can anyone help?
Simon / APP Team
#2 Posted : Thursday, November 1, 2012 4:25:55 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Unplug the range. Get access to the burner switch from the back.
Locate contacts H1 and H2 at the switch, turn the switch on, restore the power and using the multimeter check for 240VAC between those contacts.
If there is proper voltage - replace the element, if no voltage - replace the switch.
For small burner switch p/n WB23M24. for the large one - WB23M23.
Simon.
bobgjr
#3 Posted : Friday, November 2, 2012 4:16:07 AM(UTC)
bobgjr
Thank you Simon, I will try that.
Simon / APP Team
#4 Posted : Friday, November 2, 2012 9:45:24 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
Jenn-Air SCE7600W range dual burner not heating (Oven Repair (including Ranges and Cooktops))
by usethis 10/5/2014 2:01:03 PM(UTC)
by queeniegyrl5 8/23/2013 5:52:18 AM(UTC)
Range burner not heating (Oven Repair (including Ranges and Cooktops))
by rachy 5/8/2013 7:22:45 AM(UTC)
Stove Top front burner not heating (Oven Repair (including Ranges and Cooktops))
by Ribbons75 1/14/2009 6:40:32 AM(UTC)
smooth top stove - burner not heating and oven noise (Oven Repair (including Ranges and Cooktops))
by efagnan 12/5/2007 3:46:54 PM(UTC)
