Water will fill bottom container, the start to pump through the outlet pump but stops within a few seconds.
Any ideas?
Groups: APP Team
Hi.
Did I get you correctly: the d/w fills up with water then starts draining and shots off?
Simon.
The machine will stop as dion as the pump begins pumping water into the spray arm on bottom. It will try to start after that but stops at the same point once water is pumped into the lower spray arm
Groups: APP Team
