freezer set at 0 fridge at 37 freezer is at 11 degrees and fridge at 47. compressor is running but fan is not. not a lot of ice on coils but some. it will be fine for several days or weeks then the problem comes back. then goes away on its own.
also evaporator fan is working
condenser fan is working so just replace the main board,correct?
Originally Posted by: honolulublue ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) condenser fan is working so just replace the main board,correct? In the first post you said: Quote:...compressor is running but fan is not... Then you said: Quote:...also evaporator fan is working... I'm confused!!! Gene.
sorry that was a mistake. compressor and both condenser fan and evaporator fan are running.
Make sure the condenser coils on the back of the fridge are clean.
