Bad_shot
#1 Posted : Thursday, August 2, 2007 3:49:30 AM(UTC)
Bad_shot
The gas oven will not light(?). All other functions, including the Broiler and top burners work okay.
I've notice other posts where some units seem to display error codes. Not sure if this one does or not nor how to retreive them.
Any suggestions.
Admin / APP Team
#2 Posted : Thursday, August 2, 2007 10:54:56 AM(UTC)
Admin / APP Team
Rank: Administration
Bad_shot,
If your oven was "beeping out" an error code you'd hear it from every room of your house.
It's probably just a bad igniter.
Open the oven door and remove the oven bottom. There are two screws that hold it towards the back. Turn the oven bake cycle on. Does the igniter start glowing? If it does, what color is the glow? Anything but bright white = bad igniter.
You can certainly perform a more accurate test with a voltmeter and actually see what amperage the igniter is producing... if you have a voltmeter or don't mind buying one.
Anyway, let us know what you find.
Original igniter your oven model calls for: Part Details - WHIRLPOOL Ignter, oven, part number: AP3135265
Maytag brand igniter, may require the use of wire nuts (included), about $20 cheaper: Part Details - MAYTAG Oven / broiler igniter kit, flat style, part number: AP205873
Breakdown diagrams for Model SF370LEGN0
Kitchenaide gas oven will not light (Oven Repair (including Ranges and Cooktops))
by insurancelady66 2/20/2013 10:50:22 AM(UTC)
magic chef oven will not light (Oven Repair (including Ranges and Cooktops))
by david_r_shultz 1/14/2013 1:11:44 PM(UTC)
Oven will not light (Oven Repair (including Ranges and Cooktops))
by easymoney12 9/18/2012 3:49:06 PM(UTC)
by gypsyqueen 5/24/2012 8:50:45 AM(UTC)
by applianceproparts 5/2/2012 7:16:40 AM(UTC)
Gas Oven will not light (Oven Repair (including Ranges and Cooktops))
by GregM41 4/19/2012 7:28:11 AM(UTC)
by ACummings 3/27/2012 1:51:01 PM(UTC)
Oven will not light, no light on control panel but timer works (Gene) (Oven Repair (including Ranges and Cooktops))
by Xray39 10/29/2011 11:06:27 AM(UTC)
by mikenpd133 10/6/2011 6:30:33 AM(UTC)
burner on oven will not light (Oven Repair (including Ranges and Cooktops))
by jmwr 7/26/2011 5:31:55 PM(UTC)
by C Dale 7/16/2011 5:11:14 AM(UTC)
by flustered 7/4/2011 4:37:01 PM(UTC)
burners work but oven will not light (Oven Repair (including Ranges and Cooktops))
by jwohlf 4/28/2011 9:44:35 AM(UTC)
by jdiddle 10/1/2010 4:38:38 AM(UTC)
by texjett 9/2/2010 5:17:08 PM(UTC)
